Results 1 to 10 of 40
Thread: Pool Survived Vacation! ?? Chlorine levels
    mroll is offline Subscriber Thread Analyst mroll 0
    Jun 2012
    Long Island, NY
    Cool Pool Survived Vacation! ?? Chlorine levels
    Hi,
    Thanks to all you wonderful moderators, pool survived me being away 9 days...Son put bleach in 'almost' everyday and we had quite a bit of rain. However, pool is very clear BUT FC levels got higher..5.0 yesterday and 4.5 today..TC was 0 yesterday and .5 today.. PH and TA still 7.4 and 100 respectively. Did not put bleach in today.
    1) Do I need to be concerned about higher FC levels and
    2) Do I have to test the CYA again? ( last test was few days before we left and it read a questionable 30.
    THANKS...
    M
    15' round 5.7K gal AG vinyl pool; Bleach; Haywood DE filter; Haywood 1 1/4 pump; 4-12 hrs; Taylor K-2006 Tester; utility water; summer: solar; winter: Not bought yet; ; PF:21??
    Default Re: Pool Survived Vacation! ?? Chlorine levels
    If your CYA is 30, FC of 5 is fine. (Read the Best Guess Chlorine Chart in my signature below.)
    I kinda doubt that your TC was 0 and 0.5. I suspect that you mean those were your CC levels? (FC + CC = TC)
    Did you add any additional CYA after you last tested it? If not, then there is no reason to waste the reagent testing it again.
    Glad the pool survived and hope your vacation was a good one!
    Jun 2012
    Long Island, NY
    THANKS...You are Right..I meant CC...
    Nope no additonal CYA put in so I'll just continue with my 3 cups bleach I guess.Right?
    .Has not been hot and sunny for awhile though it is expected to return I guess weather including rain has kept chlorine levels up.
    Vacation was great. Thanks again.............
    It may or may not be 3 cups of bleach per night. I'm sure somewhere in your other thread, someone has given you the reference amount for your pool's bleach doses. (EDIT to add: In your pool, each cup adds about 0.7ppm of chlorine.)
    What you need to do is test your pool each evening and then add however much bleach it takes to get your chlorine back up to about 6ppm. If you find that by the time you test again the next evening that you have dropped below 3ppm, then add a little more to get to 7ppm that evening. You want to make sure that you don't let your chlorine drop below 3.
    You may want to raise your CYA up to 40-50. Most people find this makes it easier for them to keep chlorine in the pool. You can either use dichlor for a little longer, or some trichlor pucks or add a little CYA separately. Your choice.
    BigDave's Avatar
    I'm so happy your pool was still clean when you got home. One-up for your son for getting it done!
    Watermom is absolutely right: FC of 5ppm is good, you need to test and adjust your dose daily (the 3 Cups a day way just for your son), and you probably want to move your CYA up.
    Jun 2012
    Long Island, NY
    I was testing in morning past few days. Today I will test around 5:30pm today and add bleach accordingly to raise to between 4ppm and 5 ppm. This may NOT be 3 cups, right?
    I think I should test CYA again before I start adding dichlor to bring it up..Is that right also?
    Pool looks great. I wish the weather did too...Perhaps by Friday.........
  1. First "Pool-tastrophe" survived...mostly
    By RxDoc in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-16-2014, 10:37 PM
  2. Going on vacation, what chlorine level to leave pool at?
    By sunlove in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-12-2012, 02:33 AM
  3. How often to test & how much chlorine to add daily? Also, vacation upcoming...
    By blessedbeingmom in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-16-2010, 10:36 AM
