Slow down and take a breath. And, don't add any more stuff into the pool unless you area advised to do so from someone here. Adding more and more pool store products doesn't usually help and often causes more problems.
What kind of kit do you have? I'm thinking you must have an HTH 6-Way kit?
It is fine to use muriatic acid in a vinyl pool but since your pH is good at 7.6, don't worry about the alkalinity at this time. There is a thread about starting up an Intex pool that might be helpful to you. Go to the sub-forum called "Pool Chemistry for Intex-Type Pools" and read the "recipe" for starting up a new pool that is near the top. (Until your registration is completed, you'll have to log out in order to be able to see the rest of the forum.) Then, come back here with specific questions that are cleared up through that thread.
I'd also like to ask you to put your pool's information into our pool chart as this makes it easier for us to help.
Pool Chart Entry Form
Also, tell us exactly what all you have added to the pool --- meaning ingredients, not just 'shock.'
Welcome to the Pool Forum!
