Thread: If you run a variable-speed pump at half-speed, does the turnover rate double?
    Jul 2011
    Boca Raton, FL
    Default If you run a variable-speed pump at half-speed, does the turnover rate double?
    On my pool's CAD drawing, it shows that my pool's design can turnover the 16,700 gallons in 1.78 hours. I presume that means running the variable-speed, 1.5 HP pump at full speed.
    I'm currently running my pump at 1800rpms after months of running it at 2000rpms with good results. 1800rpms is very close to running the pump at half-speed.
    Question: If my pump is running at half-speed, does that mean the turnover rate doubles -- in my case, from 1.8 hours to 3.6 hours?
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
    Jul 2011
    Boca Raton, FL
    Default Re: If you run a variable-speed pump at half-speed, does the turnover rate double?
    <<moved to the correct thread!>>
    mas985's Avatar
    Pleasanton, CA
    They are referencing the maximum flow rate of the JEP 1.5 which is 150 GPM at run out but that is not achievable on typical pool plumbing. With a typical 2" plumbing setup, the JEP 1.5 HP on high speed will produce about 90 GPM or about a 3 hour turnover. And yes at half speed, the flow rate is about 1/2 and power usage about 1/6.
    Mark
    Jul 2011
    Boca Raton, FL
    Thanks for the reply. In looking over my CAD drawing, it looks like they use 4" pipes for both the spa and pool main drains (1.5" for vacuum and skimmer), and the returns are 3" to the pool, 2" to the spa return (drain), and 3" to the spa jets. My typical setup is 50/50 between the pool main drain and the skimmer, and 50/50 between the spa return and pool returns.
    But the essential question I had you answered -- half-speed pump = double the time it takes to turnover the water. Given all that you said and all that I see in the CAD drawing, I'll assume that the water is being turned over at least once a day when I'm running it at 1800rpms. Thanks again!
  1. Vacuum with variable speed pump
    By ronpbak in forum --cleanup--
    Last Post: 10-04-2012, 05:46 PM
  2. what speed on a variable pump?
    By bomberchamp in forum Pool Equipment & Operations
    Last Post: 04-11-2012, 11:53 AM
  3. Dual Speed or a Variable Speed for a plain Jane pool.
    By Lip Out in forum Pool Equipment & Operations
    Last Post: 03-14-2012, 10:32 PM
  4. variable speed pump
    By bradc344 in forum Pool Equipment & Operations
    Last Post: 01-16-2012, 09:18 AM
  5. Variable speed pump upgrade
    By kmh in forum Pool Equipment & Operations
    Last Post: 10-17-2011, 08:33 AM
