Results 1 to 10 of 11
Thread: Inground Pump and Filter Question
    BigDave's Avatar
    Default Re: Inground Pump and Filter Question
    No reason to change sand unless it's been gummed up by baquacil or some nasty growth that can't be bleached away. I believe most of the mods here are on decade + sand.
    Removing the sand does seem like a big job and I've never done it myself so I haven't any tips, perhaps someone else does.
    This is just my general skepticism but... The pool company that is advising you that removing the sand will break the laterals: Do they want to sell you a new filter? Did they install the filter 13 years ago and may be aware that the laterals have been broken since it was installed? The Hayward manual suggests filling the filter halfway with water before adding sand to avoid damaging the laterals - perhaps this wasn't done at installation.
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    You can remove the sand by first draining the filter, then vacuuming out the sand with a good shop-vac. The bigger, the better! Will not damage the laterals while removing. Be sure to fill the filter about half full of water before adding sand back or you COULD damage the laterals. Good luck! As noted above, be very careful when opening up the filter so nothing cracks-- once cracked, the filter body will have to be replaced.
    10,000 gallon IG vinyl liner pool, BBB user, salt added to 2300 ppm (because it makes the water feel great!), new liner/new water on 6/23/11, algae-free since 2006 (at least that's as far back as I remember). 1HP Hayward 2-SPEED CONVERTED Superpump, Hayward sand filter, PS234 test kit.
    Goal: To remain completely algae-free for the life of this new liner!
    Life lesson: It is what it is.
    12'x24' oval 9K gal IG pool; bleach; Hayward 244T sand filter; Hayward Super pump, 1 HP, 2-speed pump; 24hrs on low speedhrs; PS234; utility water; summer: ; winter: ; android phone; PF:13
  1. Sand filter/pump question
    By Steve V in forum Pool Equipment & Operations
    Last Post: 04-21-2013, 09:45 PM
  2. Pool, pump and filter question
    By desertdog in forum Pool Equipment & Operations
    Last Post: 06-19-2011, 05:10 PM
  3. pump/filter relocation question
    By rnjng in forum Above-Ground Pool Construction & Repair
    Last Post: 04-27-2009, 10:03 PM
  4. Pump / Filter Question
    By howdoo in forum Above-Ground Pool Construction & Repair
    Last Post: 06-11-2006, 09:36 AM
