Results 1 to 9 of 9
Thread: Does Zeolite help in removing iron from the water?
    Dec 2005
    Honolulu, Hawaii.
    Default Does Zeolite help in removing iron from the water?
    I have been reading on some websites that zeolite helps to remove iron from water and is altogether a better media than sand. The filter size is 300 lbs and the pool 9000 gals open year round with lots of air born red-dirt.
    Any opinions would be appreciated.
    duraleigh Guest
    Default Re: Does Zeolite help in removing iron from the water?
    Unless there is some chemical reaction I'm not aware of, iron dissolved in your water will pass through the zeolite just like it does sand.
    Sand works. It is in many commercial pools and in thousands of crystal clear residential pools...mine included
    Mandeville, LA, USA.
    Zeolite may be marginally better than sand but it's no panacea (and I don't think it removes any metals).
    The only chemical that I know of that zeolite will remove from the water is ammonia and ammonia compounds. This is why it ihas been used as a chemical filter medium in fresh water aquariums for many years now.
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    Typical filter sand is a round slick granule that filters by capturing suspended particles between the grains of sand. As the suspended particles build-up on the top 2-3 inches of sand, better filtration takes place. Sand media can remove particles down to about 40 microns in size. Zeolite, on the other hand, consists of a rough angular surface in additional to its micro-porous structure. As water flows through the Zeolite media, larger suspended particles are captured between the grains of Zeolite, as well as, on its rough surface. Zeolite filters down to 3-5 microns or about the same as a DE filter.
    In addition to superior filtration, Zeolite provides longer filter run times than sand. Because of Zeolite's large amount of available surface area, the filter can run 4 to 6 times, and in some cases, longer before the filter pressure rises to the point where backwashing is required. This feature conserves water and reduces the use of chemicals to maintain water balance. Zeolite also reduces the amount of head pressure in the filter. Typically, the starting pressure with Zeoliteis 2-3 psi lower than with sand. This is due to Zeolite's micro-porous structure that allows water to flow through the granules, which reduces the amount of water resistence to lower the head pressure. This feature equates to lower electric consumption by allowing the filter motor to operate at a lower Hz, which reduces the kilowatt hours used. An additional feature of Zeolite is its ability to remove ammonia and chloramines from pool water.
    My 26" sand filter required 350 lbs of sand. I only needed 175 lbs of Zeolite. I have an Iron rich water supply that comes from a south Texas well. I fill the pool from a hose with a 2 micron iron removing filter. I've also used Metal Out and Polyquat to aid in removing metals. My water has been crystal clear since startup in early March. I've backwashed one time since startup and pump runs 12 hours per day. In my opinion Zeolite is the way to go.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    duraleigh Guest
    Well, I am such a sand advocate I just have to respond.
    It seems to me that if the zeolite is capturing ALL those tiny particles that sand is missing, time between backwash and pressure build up would be greater since it's trapping so much more gunk.
    I don't think I have any ammonia in my pool (or do I?) So that benefit wouldn't help me over sand. Nor do I have any chloramines to any appreciable extent. If the zeolite removes chloramines, does that eliminate the need to shock?
    The use of a 2 micron filter and metal out may have answered the original question as to whether zeolite removes metal from the water.
    Lastly, I have yet to backwash since start-up....I've gained about 2psi in filter pressure since. based on last year, I expect to backwash two or three times this Summer. My water, thanks to this forum, is pristine.
    After all the above, I am not saying that everyone should run out and buy a sand filter. Conversely, I wouldn't be in a huge rush to use zeolite, either. If it is the "magic bullet", the marketplace will soon sort that out and sand as a medium will simply no longer exist....don't count on it.
  1. Iron out to treat iron and tea colored water
    By Fornetti in forum --cleanup--
    Last Post: 07-02-2013, 02:56 AM
  2. Well Water very High Iron
    By meadsrm in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-05-2012, 02:58 PM
  3. New Pool Owner With High Iron Manually Removing Iron
    By labdi01 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-18-2010, 02:56 PM
  4. Change from sand to Zeolite, water now cloudy
    Last Post: 05-29-2007, 04:24 PM
  5. Stain at water line after removing cover
    By mwagner in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-27-2006, 08:45 AM
