Thread: WOW my numbers are off
    Kannapolis, North Carolina
    Unhappy WOW my numbers are off
    Hey today around 2 pm I shocked the pool w/super shock, I am going to bleach but got a deal on super shock, so I go outside at 8pm and check the water, and here are the results I got, I am awaiting Bens kit but I bought one until. A lot about the pool its aa grecian vinyl 27000 gallon pool, sand filter:
    fc 2ppm
    ph 6.8
    ta 40
    cya 20
    So what I have read so far on the forum I need to raise my cya, also my alk, and definately shock for a few days trying to maintain around a 20 is this right or do you guys and gals recomend anything else.
    Default Re: WOW my numbers are off
    First, get your pH up. 6.9 is the minimum pH for a vinyl pool or a damaged liner could result. If it reads 6.8, that's the bottom of the scale and may be much lower. You need to add Borax or Soda Ash today, right now! I don't know S/A amounts, but I would start with 1 box of Borax, wait a few hours, check again, add more Borax until the pool is AT LEAST 7.0
    Soda Ash will raise your T/A as well as your pH so in this case it may be good. Or you can add Baking Soda to raise pH as the same time as the Borax.
    CYA is a tad low...but get your pH fixed first.
  1. Help me with My Numbers?
    By mkfmedic in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-07-2007, 02:28 AM
  2. Here's my numbers
    By nicoleh in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-31-2006, 12:32 PM
  3. My numbers...HELP
    By Dafreak in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-26-2006, 05:56 PM
  4. Here's my numbers
    By jnorris in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-21-2006, 06:36 PM
  5. Here are my numbers...?
    By crazimom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-17-2006, 12:28 PM
