Thread: Help Help Help , New liner bead appears to be to long!!
    Jul 2012
    NE PA
    Default Help Help Help , New liner bead appears to be to long!!
    with the help of many on this forum I am halfway though the installation of my new liner. The original was a beaded liner. The new one said unibead and is supposed to be for both beaded and j hook. Bead seams to drop in the track fine. !st attempet we went in a colockwise direction and when we met the starting point we had about 10" of bead still to go. We unhooked and tried again in a star pattern. This just seams to have divided the extra material amongst several sections. once its in the track you cant slideit left or right. Trying to set this up for daughters bday next week. need help desperately.
    round AG pool
    Default Re: Help Help Help , New liner bead appears to be to long!!
    Let me get Waste's attention to this thread and see what he can do to help you out...he's a liner installer that is a long-time member of this forum.
    Jul 2012
    NE PA
    thanks, I did manage to get it on. I kept pulling half of the extra material to next section, then half of that to next section etc. had to keep taking sections on and off for about 2 hours but eventually I got everything hooked. There was some wedge type pieces from old liner that appeared to hold liner in track so I put those back. I also picked up some mini clamps at HOme depot for about 20 cents each and they fit perfectly over the bead and bead recepticle so Iclipped a bunch of those on as well. Hope it holds , thanks again
    round AG pool
  1. bead liner keeps falling down
    By cdnpenzz in forum Above-Ground Pool Construction & Repair
    Last Post: 06-27-2012, 08:07 PM
  2. liner bead track
    By heatherc in forum In-Ground Pool Construction and Repair
    Last Post: 07-10-2011, 10:18 PM
  3. Liner pulled out in corner, appears to be no track
    By TRHOD12 in forum In-Ground Pool Construction and Repair
    Last Post: 08-11-2010, 03:44 AM
  4. which liner would you go with, overlap, uni-bead, or true bead?
    By daltrey in forum Above-Ground Pool Construction & Repair
    Last Post: 08-02-2006, 09:15 PM
