Results 1 to 10 of 10
Thread: Salt Water Chlorine Generator
    Grapevine, Tx
    Question Re: Salt Water Chlorine Generator
    Attached is the section where I'd have to fit in a 12 inch cell. I'm no plumber but do have a considerable amount of experience. Thinking of all the 90 deg.
    I'd have to install seems to be asking for trouble/leaks. Any suggestions?
    I have considered moving the whole Jandy assembly out but this would protrude 14 inches over the sidewalk. Not a viable solution.
    Thanks for your reply. I appreciate all the suggestions I can get.
    Cheers
    20,000 gal
    in-ground gunite
    DE filter
    Letro Legend
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    Default Re: Salt Water Chlorine Generator
    Another reason the cell is plumbed after the filter, heater, etc is to protect the cell from contamination. I don't think you want all the pre-filter junk going thru the cell.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    It looks like you have enough room for the cell on the left side of the Jandy valve (vertical). Dig down into the ground and install the cleaner T underground with the 1" pipe 90 out of the ground (making room). This should give you enough room to install. You will have to put a union on the pipe coming from the pump, a coupler or union on the right side of the Jandy valve, unscrew the site glass and unscrew the filter unions to do this. Hope this helps
    Lightbulb Re: Salt Water Chlorine Generator
    Blond, welcome to the forum, If you move the boosterpump feed to the line comming from the pump into the filter, you'll have all the room you need on that 2" return line to place the cell and flow switch. Hopefully this hasn't come too late
  1. chlorine generator reading low salt
    By Mrs Lauzon in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-05-2012, 04:54 PM
  2. Replies: 8
    Last Post: 04-09-2012, 04:37 PM
  3. Above ground salt chlorine generator
    By vinnybear in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-14-2011, 03:02 PM
  4. Salt water chlorine generator research
    By sevver in forum Pool Equipment & Operations
    Last Post: 07-23-2006, 07:05 PM
