Results 1 to 10 of 10
Thread: Salt Water Chlorine Generator
Threaded View
    Grapevine, Tx
    Default Salt Water Chlorine Generator
    I purchased a salt water system (chlorine generator) and have a question that Polaris has yet to answer either in their documentation or emailed question. Is it required that the cell be installed downline from the filter or can it be installed upline from the filter? I have a space issue and plumbing
    for installing the cell downline will be a problem. I've attached a photo of the pump set up. Also, can anyone identify what is what? This is a new (to me) home and pool and I am wanting to know all I can about this plumbing setup and pool. i.e. Which way do I turn the Jandy valves when I want to vacuum? My signature will indicate all my pool specs. There are additional eyeball jets located behind seating area in pool. (that will likely explain the Jandy downline from the filter)
    20,000 gal
    in-ground gunite
    DE filter
    Letro Legend
  1. chlorine generator reading low salt
    By Mrs Lauzon in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-05-2012, 05:54 PM
  2. Replies: 8
    Last Post: 04-09-2012, 05:37 PM
  3. Above ground salt chlorine generator
    By vinnybear in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-14-2011, 04:02 PM
  4. Salt water chlorine generator research
    By sevver in forum Pool Equipment & Operations
    Last Post: 07-23-2006, 08:05 PM
