Results 1 to 10 of 10
Thread: DE filter backwash (newbie)
    May 2013
    long island
    Default Re: DE filter backwash (newbie)
    Couldn't clog a brand new filter within a minute..but it seems to be working fine anyway
    DE 3620 Hayward. 16x36 Inground rectangle (1995). 7.5 ft deep end 3.5 ft shallow. loop loc cover with mesh panels
    vinper is offline Subscriber Thread Analyst vinper 0
    Texas
    I open mine up and clean grids after every 2 backwash and recharge cycles . not that hard . see what pressure reading you get on rinse cycle . you could have backpressure by a blockage or partially closed valve
    May 2013
    long island
    ok thanks..i have another question..
    when do i open the valve on the top to let air out? (other than opening it up to clean it)
    Scottsdale, Arizona
    After a backwash I let the pump run long enough to get a good circulation going and then I open it to bleed to air pressure off.
  1. PSI to Backwash a DE Filter?
    By Shifty in forum Pool Equipment & Operations
    Last Post: 07-07-2012, 03:08 PM
  2. when to backwash sand filter
    By Kateyru in forum Pool Equipment & Operations
    Last Post: 04-19-2012, 10:16 PM
  3. Backwash Filter
    By Tntoygirl in forum Above-Ground Pool Construction & Repair
    Last Post: 07-08-2011, 08:37 PM
  4. Backwash newbie
    By oroepke1 in forum Pool Equipment & Operations
    Last Post: 05-18-2011, 05:33 PM
  5. Does my filter backwash?
    By denanbob in forum Pool Equipment & Operations
    Last Post: 07-11-2006, 10:54 PM
