Results 1 to 3 of 3
Thread: uv sanitizer
    Jul 2012
    ne usa
    Default uv sanitizer
    Considering adding a uv sanitizer to my system, any information would be appreciated (effectiveness, chemical use with sanitizer, cost, installation, etc.).
    Default Re: uv sanitizer
    Hi, and welcome to the Pool Forum!
    Below is something I am copying and pasting from a post PoolDoc wrote previously in regards to UV sanitation:
    UV systems are NEVER pool sanitation systems . . . because a pool sanitation system has to treat the water in the MIDDLE of the pool. UV exists only in the contact chamber.
    UV system can have some real benefits on indoor pools, but they are essentially useless on outdoor pools.
    At the PoolForum, we do not provide support or advice on operating an outdoor pool using 'chlorine alternatives' for a very simple reason: such systems are neither safe nor effective! (Bromine systems can be, but they are sort of a "What's the point" system. They provide no benefit over chlorine, and have slightly more 'toxic' byproducts.)
    You can do more reading about UV by using the Google Search in my signature below. Until your registration is completed, you'll have to log out to see the results, though.
    Hope this helps some.
    Speedo Guest
    I've heard that UV systems help chlorine oxidize faster, but the chlorine is still the sanitizer and raising your FC level would work just as well.
  1. non-chlorine sanitizer
    By pgk in new mexico in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-04-2012, 10:58 PM
  2. Best Sanitizer / Best Way to Introduce
    By cooper in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-15-2011, 10:10 AM
  3. Non-chlorine sanitizer and equipment
    By markeast in forum Dealing with Alkalinity and Calcium
    Last Post: 07-20-2006, 01:11 PM
  4. Can't use BBB with Auto Sanitizer, right?
    By denanbob in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-03-2006, 01:05 AM
  5. Zodiac Nature2 Proffessional IG Sanitizer
    By JonnyG in forum Pool Equipment & Operations
    Last Post: 06-10-2006, 07:18 PM
