Thread: Water Boatmen in my pool...
    Default Re: Water Boatmen in my pool...
    This doesn't sound like too good of an idea to me. Putting liquid dish soap into a pool may turn into a pool full of suds and bubbles which would be extremely hard to clean up! I don't think I would advice following this suggestion. Just my $0.02.
    Welcome to the Pool Forum, by the way!
    Lehigh Valley, PA
    We use dish soap in water to drown stinkbugs, a house pest, not a pool pest. It does work very well to break surface tension. IMO, 2 teaspoons dispersed over the entire surface area of a backyard pool aren't harmful to the pool and if you do wind up with some minor soap bubbles, that sounds far preferable to the water boatmen infestation. I'm surprised you have them in Canada. I always thought they were more of a warm climate creature. We haven't seen any here in our pool, knock on wood.
    One thing: with such a large amount of water insects they obviously have a food source in your pool water. What is your water chemistry like?
    Some people report that using 50 ppm Borates in the pool has the same effect of keeping the water boatman away. I suspect it is for similar reasons of reducing the water's surface tension which is one of the effects of having the borates in the pool.
    Water boatmen eat things that shouldn't be in your pool: algae, tiny bugs or small amphibians.
    There are 3 reasons why there's something in your pool to eat:
    1. You have algae. If so, eradicate it.
    2. You have bugs that are living in your pool . . . but such bugs live on algae. See #1
    3. You have bugs that are landing on your pool, because of night lights OR the reflections of night lights. Turn off the lights; block the reflections.
    4. You have bugs that are randomly migrating or falling into your pool. This is not easy to fix; use the solutions above.
    Apr 2012
    Texas
    No matter how high my chlorine level is, I seem to always have at least 1 sometimes 2-3 of these things. I scoop them out and they get back in. Haven't had algae since spring so I don't know what they are eating or why they decide my pool is a better home than the pond! I am afraid to try dish soap, my pool is on the small side so that could be disastrous. I once bought an off brand of bleach and it caused a small amount of foaming, must have had some kind of surfectant (sp) in it, I wish I remembered where I got it, I'd start using it.
    18' round 7.5K gal AG vinyl pool; bleach; Hayward C900 cartridge filter; Hayward Power Flo Matrix 3/4HP pump; hrs; HTH 6-way test kit
    ; community; PF:16
    Waterbugs fly.
    They are going to investigate water bodies in their range. There is absolutely nothing you can do to prevent that, except enclosing your pool. So you can't keep them from arriving, but you can keep them from wanting to stay!
  1. Chlorine Pool Water seems like salt water?
    By heatherc in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2012, 05:04 PM
  2. Salt Water Pool Water Smells Like Must
    By desherer in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-28-2011, 02:20 PM
  3. got new 24x5 round intex pool need help with water. Sandy water..help
    By iwannaswim in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-08-2011, 09:42 PM
  4. Water boatmen!!
    By CanuckPool in forum Pools, Pets and Creepy Critters
    Last Post: 07-24-2007, 12:18 AM
  5. I found a water boatmen in our pool...
    By gonefishin in forum Pools, Pets and Creepy Critters
    Last Post: 09-12-2006, 12:09 AM
