gregugadawg
Just one conflicting point here, I wouldn't say that running your equipment 8 hours a day is more than sufficient run time. 8 would be a bare minimum to run it. Typically most pools are designed to turn over in 6-8 hours, in the middle of the summer you would want to run the pump a minimum of 12 hours during the heat of the day. 8am-8pm is normally recommended, you don't want to run it in the morning and off during the day and at night, you want at a bare minimum 8 continuous hours during the heat of the day. And to be honest most people will agree if you can afford the little extra to run it 24 hours a day it will save you money in the long run and a lot of headaches.
