I have one of those 11KW electric heaters and depending on how much you enjoy a warm pool/spa is the key to it's use.
The fine members here who know what they are talking about suggested solar to me. As a test case I got one of the small Game circular solar heaters. In early-mid May, just one barely would keep the pool at the temp it was. I added one more and all was very well and I was able to increase temp by 2-3 degrees a day in roughly 7 to 8 hours of direct sunlight. Now that it's upper 90s to 100 here I have the covers on the solar heaters and figure once it get's below 85 I will uncover them for that nice warm water pool effect.
If I had it to do over I would either make my own solar system with PVC and some sort of box type setup or I would get the large Game circular solar heater and be done with it.
So my final comment is, I like having both. I will try and run my pool on "free" heat for as long as I can, then and only then will I make the decision to turn the electric heater on. And if you are wondering, the electric heater will keep the temperature constant with the outside temp in the mid 60's with everyone in it. I am using this only to extend the use of the pool way later than most "normal" people.......but that is a choice I have made and running the electric heater does cost me.
Bob E.
