I have an in-ground pool, it is sparkly spray texture type of finish, I have one skimmer, two drains, 3 jets, the pipes look to be 2 or 2 1/2 inch, the pump is a Marathon 1hp pump
http://marathon-motors.com/C1245-5KC...-Rpm-C1245.htm
Just an update, the crack started gushing yesterday so I removed the canister. I will need to replace or fix asap. Also my pipes are 2".
Looks like the part is available: http://www.pentairpool.com/pool-owner/partslists/filters-cartridge-system-2-modular-media-filters-plm-series-152.htm. It also looks like you can use larger filters if you want to.
Yeah they wanted $305 for the bottom part that's cracked. I got a whole new PLM 100 with filter for $340 locally. Already installed, and it's working great!
And now you've got spares for the top parts! - If you have 'em you'll never need 'em.
