Thread: Using an in ground cleaner in an above ground pool
    Jul 2012
    Central Oklahoma
    Default Using an in ground cleaner in an above ground pool
    We bought a Hayward sharkvac online. It got here and I read the instructions and put it in the pool. It sunk down and I turned it on. Then I realized it said "INground Pool Cleaner" on the box. It was not specified on the website, I looked but never saw any indication. Can I use it in my pool? What is the difference
    John
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    Default Re: Using an in ground cleaner in an above ground pool
    Hey Johnnymac,
    The main difference is that in ground robots are meant to climb the walls of your pool to help keep the waterline clean. I think this would cause alot of stress to the walls of an above ground pool, and perhaps cause damage to them. While I'm not familiar with your particular cleaner, if it has a setting that allows it to clean the floor only, it may be okay. Personally I would try to return it for a model specifically designed for an above ground pool.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
  1. Automatic Pool Cleaner for Above-ground pool
    By spunsilver in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-28-2013, 11:37 PM
  2. Robotic cleaner for vinyl in ground pool
    By jules0804 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-20-2012, 01:54 PM
  3. Giving away an in-ground gunite auto pool cleaner..
    By pbotz2000 in forum Pool Equipment & Operations
    Last Post: 04-11-2012, 09:27 AM
  4. Hayward Aquabug Automatic Above Ground Pool Cleaner
    By MaxxFusion in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-12-2006, 09:41 AM
  5. in ground pool cleaner
    By jgentilemd@aol.com in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-11-2006, 03:52 PM
