Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: something on the bottom of the pool
  1. #21
    Jun 2012
    IN
    Default Re: something on the bottom of the pool
    Thanks for all the help! I think I'm almost good! The vaccuming to waste is really working. It's a slow process though because I lose so much water that I have to stop and refill my pool before I can vaccum the whole pool. I can't vaccum too fast or it stirs the stuff up but at the rate I'm going it is taking a lot of refilling. I've probably got 80% of it out. A couple of more vaccums and hopefully I'll have it.
    Is the key to avoiding this mess again just to really make sure I don't get low on chlorine?
    I did the chlorine overnight test and I didn't lose chlorine so I think it's just dead algae that I have to get out, my filter doesn't seem to trap it.
    27 Foot Round Above Ground. Sand filter
    27' round 17K gal AG pool; Liquid chlorine- sodium hypochlorite; sand filter; pump; 24hrs; HTH 6 Way drop kit; well; summer: ; winter: ; ; PF:7.1
  2. #22
    Quote Originally Posted by bjaeram View Post
    Yep, the easiest way to deal with algae is just to not let it get started in the first place!
  3. #23
    . . . so true!
  1. Can't get bottom flat, can pool bottom be slightly concave/bowl shaped?
    By SkierDude in forum Intex-type Pool Setup & Operations
    Last Post: 06-30-2013, 12:13 PM
  2. pool bottom
    By 1bigdeerhunter in forum Above-Ground Pool Construction & Repair
    Last Post: 05-23-2010, 03:29 PM
  3. Help,not sure what this is on bottom of pool
    By sisie5 in forum Dealing with Algae & Slime
    Last Post: 09-02-2006, 01:42 PM
  4. what is this in the bottom of my pool?
    By martinsvillemark in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-05-2006, 11:29 PM
  5. Pool bottom
    By crosso in forum In-Ground Pool Construction and Repair
    Last Post: 04-03-2006, 12:40 PM
