Came out to the pool this morning and found the pump pot empty. Looked in the pool and found it down 8", maybe more. Yikes!!!!
We discovered four very tiny tears in the liner, maybe 1/4", behind and under the wedding cake steps in the cove. What likely happened is that the metal end of the hose banged into the liner. Yes, we did leave the hose behind the steps while the dogs used the steps as jumping off points. So very dumb of us!
We patched them using a kit that has heavy duty clear vinyl and a tube of glue. Do we need to weigh the patches down? We can put a bag of sand on the ones in the cove but how do you put pressure on the ones on the wall?
The leaking water flushed out a considerable area of sand and we now have a good sized dent in the bottom, abut 12" x 12". Will that cause us grief in the long term?
I'll post pictures as soon as I've got them downloaded off the camera.
