Results 1 to 10 of 14
Thread: Converting 15' Round Intex to Hard Plumbing
    May 2012
    Oklahoma
    Default Re: Converting 15' Round Intex to Hard Plumbing
    Ryan, I modified my "little" Intex pool with the big intake and returns since they came with the big Intex pump/filter. At this point in time, unless you are willing to live with the leak you will have to drain at least some water out of your pool.
    You will have to cut around 1/4 of an inch of material off to allow the installation of the bigger return in the hole. You will be OK by just following the installation diagram of the parts installation guide. THEN you can hook up your big hoses with the valves and all will be well. I have hard plumbed after my first 6 foot of hose from the pool (the pool bends and flexes so you have to allow for movement....period).
    However, all conections to Intex equipment are connected with intex hoses first (for the length of the hose) then to the hard plumbing. You will find that if you use a 1 1/2 rubber PVC pipe connector cut into 1/8 inch washers (similar to your garden hose washers), you will have no leaks when connecting 1 1/2 inch Intex hoses to a 1 1/2 inch PVC threaded connector. You WILL have to make or buy a washer. Cutting is very easy if you put a 1 1/2 inch PVC pipe into the connector, then using your cutoff saw you will be able to make repeatable cuts and similar washers.
    Bob E.
    Intex 10' x 30" metal frame pool, Intex 2500 gph filter/pump, Intex Saltwater generator, SwimMax 11KW heater, 2 x Small Game Solar Domes.
    Jul 2012
    Merrimack, NH
    Thanks everyone for the replies.
    I went ahead and cut out the small intex connections and replaced with the larger.
    Everything is working well, and flowing better.
    Safetybob,
    Do you still use the intex plungers??
    Ryan
    May 2012
    Oklahoma
    A little late replying, but yes, I still do use the Intex plungers. Incase I didnt' say it, I also use the "big" Intex inlet and outlet, plungers that came with the big pump and the 1 1/2 inch hoses. I may also work on hard plumbing a bit more next year. Found 1 1/2 inch pool/spa cream colored tubing at Lowes to try out. Looks heavy duty enough, but problem is connecting it to our unique Intex stuff. More experimentation needed.
    Glad everything is working better.
    Bob E.
  1. Anyone buy the new 27' round Intex yet?
    By ThaSatelliteGuy in forum Intex-type Pool Setup & Operations
    Last Post: 05-13-2012, 02:48 PM
  2. Intex Ultra Frame Pool Hard Plumbing
    By labmom56 in forum Intex-type Pool Setup & Operations
    Last Post: 05-08-2012, 01:34 AM
  3. Hard plumbing
    By msummers in forum Above-Ground Pool Construction & Repair
    Last Post: 06-28-2011, 07:55 PM
  4. Securing hard plumbing for AG + solar panels
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 08-17-2007, 08:06 AM
  5. Hard Plumbing
    By scsteven in forum Above-Ground Pool Construction & Repair
    Last Post: 07-21-2007, 10:18 PM
