Thread: Bleach and Chlorinators
    zelmo is offline ** No working email address ** zelmo 0
    Dec 2005
    PA.
    Default Bleach and Chlorinators
    I am concerned about damaging my solar cover by adding the strong concentration of bleach and water, and I'm wary of dumping it into the skimmer. Now that I am using bleach the Hayward automatic chlorinator is not doing anything. Has anyone tried putting the bleach into those since it is located downstream from the filter and heater? Seams like it should mix the bleach with pool water and return it in a diluted state.
    Rehoboth, MA
    Default Re: Bleach and Chlorinators
    If you pour your bleach into the skimmer it is getting diluted - first if your pump runs at 30 GPM, that would be 1 gallon of water every 2 seconds going through the pump. How long would it take to pour in a gallon of bleach? If you tried to do it as fast as possible, I would guess it takes at least 10 seconds so at the bare minimum you have diluted the bleach 1:5 before it even hits the pool. Then when it does hit the pool, the return is several inches below the surface where the solar cover is so even if you have the jet pointed up (which you probably don't) the bleach gets further diluted before it would ever get to the cover. After you finish pouring the bleach, then you have water without the added bleach continuously coming out behind it to keep pushing it away and quickly mixing it with the rest of the pool water. I don't see how the bleach could possibly damage the solar cover unless you add enough to bring the entire pool too high - I can't recall if my solar cover mfg. recommends not using the cover when shocking or not.
    Peter
    Dec 2005
    PA.
    I wasn't worried so much about the solar cover when putting bleach in the skimmer as I was the pump and heater. Won't the bleach damage seals?
  1. Chlorinators
    By ImpalaRob in forum Pool Equipment & Operations
    Last Post: 08-22-2012, 07:50 PM
  2. Las Vegas, NV 13,000 gal salt pool- 2 Jandy chlorinators with issues
    By jennxxrr in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-26-2012, 11:29 AM
  3. New here...Considering salt water systems or auto chlorinators
    By jeremyp in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-03-2012, 11:45 AM
  4. CYA and salt chlorinators
    By DanS in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-18-2007, 10:29 PM
  5. salt water chlorinators: Zodiac LM2-24
    By Pool_Mike in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-06-2006, 09:51 PM
