Thread: next question-UNDER liner? What did you use?
    Jun 2012
    Florida
    Default next question-UNDER liner? What did you use?
    I have ordered the pool! It should be here by Wed. of this week. SCARY but SO excited!
    So what did you use under your pool liner (over the sand that is)?
    Has anyone used poly styrene? It is insulation I can get from Lowes. It seems that it would work and be much cheaper.
    Kim
    Default Re: next question-UNDER liner? What did you use?
    With my newest pool installation, my installer used the Happy Bottom foam. Under my previous pool, my installer (different guy) used a pink foam from Home Depot but I can't remember what it was called. It wasn't specifically made for pool installations but had some other purpose. It worked fine. I'm sure it was cheaper than the Happy Bottom foam.
  1. AG liner question
    By pool kristi in forum Above-Ground Pool Construction & Repair
    Last Post: 03-07-2012, 08:06 PM
  2. Spring Vacuum Question and Liner Question
    By DougM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2011, 12:11 AM
  3. Liner Question...
    By poolmom06 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-08-2006, 02:42 AM
  4. New liner question....
    By Waterdragon in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-19-2006, 01:43 AM
  5. Liner question??
    Last Post: 05-15-2006, 10:19 PM
