Thread: I cannot get enough chlorine in the pool
    Jul 2012
    Ohio
    Default Re: I cannot get enough chlorine in the pool
    I have read the info, and now I am sort of nervous Only question I have is does the time of day I add it matter? Can I add the muriatic acid and chlorine at the same time tonight or should I space it out
    It doesn't matter what time of day. Adding the acid a few minutes after adding the bleach is not a problem. (Maybe 15 minutes or so should be fine.)
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 11:53 PM
