Results 1 to 10 of 71
Thread: Chem log, to see....
    Jul 2012
    Mexico, Missouri
    Default Re: Chem log, to see....
    Here's the one I ordered: http://www.amazon.com/gp/product/B00...ls_o00_s00_i00 As far as I can tell, the T would be for Timer, yes. The EG seems to mean Electronic timer, with GFCI.
    It came with new bulkhead fittings, valves and hoses, and suction/return screens. Good deal for the money!
    All that is required for you to use the larger fittings is remove the smaller ones that the 637R needs, and CAREFULLY cut the hole larger to fit the new fittings.
    We did ours without a partial drain, by using a large plastic bowl held to the side of the pool while removing the old. Then covered the hole from the outside after enlargement long enough to get the inside portion of the new fitting to the hole. Then the bowl back over the hole, and tighten the ring nut to the fitting, with the valve in place on it. Didn't lose more than a few gallons of water this way.
    Yes, I'll be buying the Unicel carts next payday. These Intex branded ones, you can almost see through the filter material, it's that thin. Lets a lot of fine material blow through.
    One of the things I really like about the 633 is it's a pressure feed to the filter, instead of a suction through the filter. If I can find a good spot on my filter canister, I'd like to add a pressure gauge, maybe two. One before the filter, and one after. Call it a differential gauge set-up. There actually are gauges made for this purpose, but would require a bit of small tube plumbing, and those gauges get rather expensive.
    Agreed on the algae thing. After only one day with the new pump, the much superior water flow had helped kill the algae I do have. Swept the pool several times today, and each time less of the brown crud settled back out. With the smaller pump, it seemed like the brown crud increased.
    I don't think you will regret buying the larger unit.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Jun 2012
    Michigan
    Thanks for the info! I love the bowl idea, very clever!
    I haven't decided if I'm going to order now or wait until next year. I'm kind of afraid if I don't order now the price will be back up beginning of season thou.
    I don't know that I have the confidence to be cutting the holes bigger. I'm going to think about it for a few more days before making my decision. I know it's necessary if I want better flow/circulation as I'm confident that is why I can not totally get rid of this algae. I'm also taking the pool down Labor Day Wknd so would only be using the new pump for a week or so. Not sure that justifies ordering now.
    I'm assuming the skimmer that came with your pool isn't adaptable to the new pump fittings? I love the skimmer and use it daily since all of a sudden out of no where we are having a Flying Ant invasion! Started a week ago and it happens almost exactly the same time every day. They land in the water faster than I can hand skim them out, VERY Strange! Every cpl of days I clean out my filter and put it back in. You wouldn't believe the amt. of ants that are in there. The first time I changed the filter out and left the dirty one sitting outside, the next day I went to throw the filter away and as the ants were beginning to dry out they began to fly away. That was even after I poured bleach thru the skimmer the night before I pulled it to help with the algae problem.
    I'm not even using my SWCG since I drained, moved and refilled the pool. I just finally got the water balanced in the last cpl of wks and just couldn't justify dumping 120lbs of salt in for maybe 4 weeks of swimming. Those bags are heavy and kill my back, hands and wrists which are already messed up from redoing this pool the second time. Like once wasn't enough! I wish my body was still as young as my brain thinks it is. lol
    Ok now I'm just rambling! Thanks again for the info and I'm glad the conversion went well for you & good luck I hope this is the answer to your algae problem.
    15' x 48" round 4.4K gal Intex AG pool; Unicel Type C-5315 cartridge filter; Intex 633T pump; (24/7) Taylor 2006 kit; utility water; summer: ; winter: ; iPhone; PF:27
    Jul 2012
    Mexico, Missouri
    I think it would be a good idea to order the pump now, and have it on hand for next year. When you set it up again, you can do the conversion before filling.
    The bulkhead fittings have two sets of threads inside the pool, so all the inside things will still work with them.
    Jul 2012
    Mexico, Missouri
    Ok, this is getting annoying. Since I am having a constantly recurring loss of cl overnight, I took it to 35ppm last night. First test this morning showed 25.5ppm, for a loss of almost 10ppm. This is ridiculous. So I am going to try 50+ppm, and risk a bit of liner fading.
    It is important to me that I learn to get it right, because this may be the only time I drain for overwinter.
    As noted in previous posts, The liner will be cleaned up of as many flaps of extra liner as I can safely do, giving algae less of a place to hide. Those flaps along each seam are difficult to clean out, and keep clean. And may be the source of the recurring problem.
    Anyone have any thoughts/feedback?
    Jul 2012
    Mexico, Missouri
    Ok, I've got the FC up to 50, and I actually have measurable CC of 1, along with a chlorine smell to the water. It would appear that anything less is just holding it down to an "it's still here" level. We'll see how much I lose overnight.
    If you smell it, then it's working on something! Might want to check it again before you go to bed, because if you're smelling it, then you've already lost some to CC.....
    Jul 2012
    Mexico, Missouri
    Just came back in from my morning check. Even with the cover on, I could smell the chloramines. Some people say that chloramines smell just like bleach from the bottle, I think they need to do a comparison smell test. That would open their eyes, quite literally! The two don't smell anything alike, at least to me.
    Anyway, on to the results:
    FC=47, so dropped 3 overnight. The results posted last night were the final, about an hour after I dosed and covered the pool.
    CC=1, so combined with the odor, means I'm hopefully getting a handle on this, finally!
    No need to do a pH test, wouldn't be accurate anyway, with the chl level.
  1. Does anyone buy chem from wholesalers?
    By pmeloy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 11-29-2011, 02:37 PM
  2. Calling All Chem Geeks (incl. THE Chem Geek) re: storing pool chems
    By elsie in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-10-2011, 10:20 PM
  3. Which chem to increase ph?
    By kelemvor in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-16-2011, 05:14 PM
  4. Trying to keep up w/ Chem Geek
    By ShelleyAnn in forum Pool Equipment & Operations
    Last Post: 04-23-2007, 03:30 PM
  5. Help with water chem., and SWG
    By guild1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-28-2006, 01:39 PM
