Thread: So confusing about chemistry!!!!
    Jun 2012
    PA
    Default So confusing about chemistry!!!!
    Hello,
    Ok HELP!!!!! I have my pool up for a week now and can't really afford the test kit you memtioned but I was able to get teh HTH 6 test kits from Walmart. HELP!!!!!
    What clorine should I buy? I have an intex 18 x 48 pool where the sides go up when you fill it up.
    All the numbers seem to confuse me!!!!!
    Please help Aaron Ogitis
    Default Re: So confusing about chemistry!!!!
    Buy regular unscented bleach and use that for your chlorine. If it is an 18x18x4 square pool, then 1 gallon of bleach should put your free chlorine level at 6 ppm. (9700 gal)
    If it is an 18' round then 3/4 gallon should put your chlorine level at 7--a reasonable start, assuming your water hasn't gone green yet.
    You'll need to review all our info on the B-B-B system of pool care (Bleach, Borax and Baking Soda).
    I will tell you this: while the 6-way drop kit is pretty good, the Taylor K-2006 is far better and will save you thousands over the years. For the $50-$70 it costs, it will pay for itself in no time.
    Since it is a fresh fill, you may want to use dichlor which will add chlorine and needed stabilizer (CYA) at the same time. Take a look at the following thread about starting a new intex pool.
    http://www.poolforum.com/pf2/showthr...p-routine-care.
    What is the source of your fill water? A well or a municipal water supply?
  1. Chemistry
    By Clodbuster in forum --cleanup--
    Last Post: 05-20-2013, 10:37 AM
  2. Confusing info from Taylor Technical support
    By fishandfly in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-24-2008, 09:00 AM
  3. Chemical reaction confusing
    By donaldm823 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2007, 11:08 AM
  4. Confusing CYA readings
    By mshumack in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-26-2006, 03:04 PM
  5. Ok- kind of confusing to explain...
    By Madty in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-14-2006, 03:35 PM
