Those numbers look pretty good other than the pH being a little high. You can use some muriatic acid to lower it. Read the muriatic link in my signature below.
The way you do the test is to fill the little bottle to the 7ml level with pool water and then fill to the 14ml line with the R-0013. Cap it and mix it and then wait at least 30 seconds. Then, holding the test block at waist level in natural light, slowly squeeze the contents of the bottle into the tube, noting when you can no longer see the black dot. If it doesn't get cloudy, then your CYA level is less than 30.
How long has it been since you used dichlor, added CYA separately and used trichlor pucks? You'll want 40-50ppm of CYA in there. So, you'll need to use one of the three mentioned to bring it up some.
By the way, use the 10ml testing sample instead of the 25ml. It will save on your reagents.
