Thread: Above ground steps
    Jul 2012
    Massachusetts
    Default Above ground steps
    We are looking for ways to weigh down our above ground pool steps.
    Default Re: Above ground steps
    Hi, and welcome to the forum!
    Many of our users have used bags of sand and bags of rock--and some have drilled holes in the bottom of the steps to let the water help weigh them down. Until you get some others to chime in with suggestions, you can search through the forum by logging out and using the google search linked in my sig.
    Lehigh Valley, PA
    We have the wedding cake style steps and made weights from large diameter PVC pipe filled with QuickCrete and capped at both ends. There are photos in the link to "My Pool Pages" in my signature below.
    BigDave's Avatar
    I used soda bottles filled with pea gravel, then water and a tablespoon of bleach and capped full of water (cap them underwater if possible).
    Jun 2012
    St. Louis, MO
    I used a couple of the 182 oz bleach jugs... filled them with quickrete (dry, didn't even mix it) Capped them and in they went. We intended to get them wet and let them cure out of the pool but just haven't done it yet.
    30' Vogue Vectra ABG
    27' round 17.1K gal AG vinyl pool; BBB; WaterWay 26in sand filter sand filter; WaterWay 2hp, 2 speed pump; hrs; TF100; utility water; summer: solar; winter: vinyl / water bags; ; PF:7
  1. Whats the difference between in ground and above ground sand filters ?
    By sherriemoseley in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 01:31 PM
  2. Steps for a 54" wall above ground pool?
    By Watermom in forum Above-Ground Pool Construction & Repair
    Last Post: 05-23-2012, 12:35 PM
  3. Filling our NEW AGP now, but need help with ground wire/ground field?
    By TheVanDams in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2011, 11:38 PM
  4. Above ground pool ladder - ground had to be leveled 1' down in yard
    By lori0479 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-21-2011, 01:50 PM
  5. Investigating partial in-ground/on-ground pool
    By jcmjrt in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2006, 06:31 PM
