By the way, I reminded Poconos today that he was supposed to do this. He said he was sorry that he had forgotten about it, but would do it tomorrow.
We built a shallow rectangular box, painted it black, glued on a clear plastic top. Before gluing on top we took a black hose and coiled it inside, so both ends of the hose were coming out a small hole at one end. Also used wood wedges to keep hose in place. We used a sump pump to move water from the pool through the coiled hose and through an additional black hose on the ground. With the sump pump on a 30 minute cycle timer, it helped raise the temperature.
Hope you get warm soon.
33' round 25.6K gal AG pool; bleach; Hayward SwimPRO voyager cartridge filter; pump; 24hrs; currently: Taylor 2006c; well; summer: ; winter: ; ; PF:4.7
33feet, I like your construct! We don't have the space to put up solar panels anywhere near the pool but we could easily manage a box such as yours. How long are your hoses? How many 30 minute cycles do you run? Does the box have a solid top under the black vinyl? On second thought, probably not . . . the vinyl is your solar collector, right? Is the box tilted to allow rain water to drain off? Any chance you could post some photos? If so, please e-mail them to poolforum at gmail dot com with reference to this thread and Ben will post them.
I have sent a photo. The overall box is 44" x 33", made of a plywood bottom and 2 x4 sides. It is painted dull black. I am not sure how long the hoses are, we used two to coil in the box. One of the hoses was green, spray painted black. There are two wood pieces that are attached to keep the hose in place. On top of the box was a clear plexiglass sheet to help heat the hoses. In the upper left corner of the photo you can see the in and out hoses. The in hose was hooked to a sump pump in the pool. The sump pump was placed on the timer at 30 minute on/off. It was running whenever it was warm enough to heat the water. The out hose was connected to a black hose that laid on the ground and returned to the pool for additional heating. The box was was nailed together.
It could be tilted to allow rain water to drain off. It is very portable and we are currently not using it now as the pool water is warm enough.
Hope this helps someone.
Thank you much for the additional description! I know we have all of the bits out in the garage and the loft, including the plexiglass, to make the box. We'd have to buy the hoses and the sump pump. The little swimming pool cover pump we have is likely not powerful enough. Looking forward to the photo!
I found a ton of detailed plans for DIY solar pool heating, here is a link to the one I am going to try hopefully, but follow links on page to other versions including similiar to pocono one mentioned above. Very detailed down to type of tubing to use.
http://www.builditsolar.com/Projects...wCollector.htm
ps also looking at one for potable hot water, veryinteresting stuff out there
round AG pool
Thanks for the link!
