Thread: stupid gasket question
    May 2012
    Iowa
    Default stupid gasket question
    The new gasket for my inlet is rubber cork and rubber. What is the sequence of these gaskets?
    thanks in advance
    bssage
    BigDave's Avatar
    Default Re: stupid gasket question
    I will guess that one rubber goes against the liner on the inside of the pool, one rubber against the wall on the outside of the pool, and the cork on top of that, under the nut to allow it to slip. This is a steel wall above ground pool, yes?
  1. Stupid question - vacuum to waste
    By OddJob in forum Pool Equipment & Operations
    Last Post: 07-31-2010, 11:40 AM
  2. Stupid Question...
    By Ken S in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-10-2010, 10:27 PM
  3. Stupid question?
    By Mojo1 in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-06-2009, 01:34 AM
  4. probably a stupid question...
    By Cammie895 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-12-2007, 08:08 PM
  5. Stupid question about DE scoop
    By poolmikecalif in forum Pool Equipment & Operations
    Last Post: 04-18-2006, 01:39 AM
