Results 1 to 10 of 16
Thread: Confused
    May 2012
    Indiana
    Default Confused
    We filled up our Intex pool (6500 gallons 18x48) with well water and finally got it cleared up and we were using bleach but I felt like I was adding it every day so we switched to some chlorine tablets in the skimmer. We had added CYA and today it tested at 55, pH is 7.2, Chlorine is ZERO. I don't know what we should do to get our Chlorine up and keep it up. Maybe it is easier to just use bleach...I'm so confused. Can someone help me figure this out? Thx.
    Lehigh Valley, PA
    Default Re: Confused
    Most of us do think it's easier to use bleach. Some people can buy liquid chlorine in 5 gallon carboys at a pool store. That chlorine has a concentration of around 12% and you use less of it, and you don't have the hassle of bleach bottles.
    Your CYA is good. The chlorine tablets in your skimmer will continue to raise the CYA and lower the pH and yours is already at the very low end. I'd stop using the tablets. Get some 20 Mule Team borax and add 1 1/2 cups. Let it circulate for an hour, test pH again. What is your TA?
    Each gallon of 6% bleach will raise the FC by approximately 10 ppm in your volume. 1/2 gallon would be 5 ppm and that is the level of free chlorine you want to maintain with CYA at 55. How often and how much to add bleach depends on so many things that we really can't tell you. Test FC and pH daily, keep a log in a notebook or digital file, add bleach as necessary to keep the 5 ppm.
    If this were my pool I'd put a gallon of bleach in it right away just to forestall an algae outbreak which will happen very quickly without any sanitizer in your water.
    Oval 12.5K gal AGP; Hayward 19" sand filter; Pentair Dyn 1 HP 2sp pump on timer
    [URL="http://www.ellerbach.com/Pool/"]My Pool Pages[/URL]
    May 2012
    Indiana
    Thx..I am off to get more bleach and borax. I'll post back TA and pH..thanks!
    Most folks who use bleach do add a maintenance dose every day, usually in the evening after the sun is off the pool. The only way to use bleach without having to add it daily is to increase your CYA to a higher level so that it last longer--but I would not do that with a metals pool because it will be a total nightmare if you let algae get started because of the high levels of chlorine needed to shock.
    May 2012
    Indiana
    Our pH is about 7.5, FC 6-10, TA took about 30 drops to get from green to pinkish red. I am using the HTH kit from Wal Mart.
    What kind of main dose should we add each eve? thx!
    Lehigh Valley, PA
    I'm not sure how to interpret your HTH test results. pH at 7.5 is good. FC "about" 6-10? With a DPD powder and FAS drop kit there isn't any 'about'. I have never used an HTH kit and so I can't really question or discuss the results.
    Wild guess? Add 1 quart chlorine at night, test in the morning. If you're between 3 and 6 ppm FC, you're good. If you're below 3 ppm, add 1/2 gallon, instead. The chlorine demand changes depending on how much the pool is used.
    Lehigh Valley, PA
    Quote Originally Posted by newbiepool View Post
    Because I am not familiar with the HTH kit I would like to ask you or someone who does use this kit how TA is tested for. The Taylor kit I use values each drop of titrant at 10 ppm. If, with my kit, I counted 30 drops to get from green to red (or pink) I would have a TA of 300. I just want to make sure that we're working with the right number.
  1. confused on cya
    By johnlanciloti in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-30-2011, 08:47 PM
  2. I'm Confused
    By Lisa Tone in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-05-2011, 04:17 PM
  3. I'm confused
    By topless in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2007, 10:29 AM
  4. Confused about CYA
    By circlenranch in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-01-2006, 08:16 AM
  5. I'm a Little Confused ...
    By vinnygnj in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-28-2006, 09:28 PM
