Ok, we're still trying to figure this one out...
I have an in-ground, gunite pool (almost 5 years old) & I live in Southeast Louisiana. For the first 3 years, we used an electric, copper ionization system. At the end of the 3rd season, we removed the copper bars and tested the water; it showed almost no copper in the pool. As it was nearing winter, we let the pool filter just run but did not add chlorine until the following spring.
All last summer, we used chlorine with great success! It was SO much easier than the copper ionization system!
This winter, we did not neglect our pool as we previously had, but we didn't keep it completely *up* either... When we opened it 3 weeks ago, there was some leaf debris and algae, but we could see the bottom of the pool and the chemistry was not WAY off...
We vacuumed the pool thoroughly, soaked and rinsed the cartridge filters, and then added acid & (after 3 hours) shocked the pool. Two days later, I added black algetrine because I noticed the black algae trying to come back (a problem that was introduced during our copper ionization days). Our calcium hardness was a bit low, so we added that a couple of days later. All of our levels are now *perfect*, and the black algae is all but gone, but there is this stubborn, orangish-brown stain on the bottom of my pool and at the base of the walls (where the floor curves up into the wall). The walls are pristine; no algae or stains at all.
I have scrubbed and scrubbed. The local pool store is baffled. Then I reminded them that we used to use copper so they tested for that and it came back positive! HOW is that possible??? It's been almost 2 years since we have actively added copper to the pool. I know some algaecides use copper; did the black algaetrine do this? Is this stain even related to the copper level in my pool or is it something else entirely?
I could really use some input here; I'm still a bit of a novice at all this and I don't want to do anything wrong & really screw up my pool.
One final note (sorry to be so long-winded): Yesterday (per my pool store's instruction), I added 1 quart of Metal-Out to my pool with the instruction to wait 2 days, rinse my cartridge filters, and then repeat the process. It has been nearly 24 hours since I added the Metal-Out and there has been no noticeable change in the stain so I'm wondering if this is even the right course...
I truly appreciate any help or direction you can give me!
Thanks in advance,
) but why wouldn't Metal Out remove iron from the water?
