In addition to needing room for a cover also consider these factors:
Replacing A Liner: Your top rails will need to removed so that you can change your liner.
Replacing Your Pool: Say 10 years down the line you replace your pool. If you built it to fit a 48" pool, then a 52" or 54" pool won't work with your old deck.
Josh
