Closed Thread
Results 1 to 10 of 10
Thread: Started to use HTH products for 12x30 metal frame pool Want to switch
    Jun 2012
    Default Started to use HTH products for 12x30 metal frame pool Want to switch
    Hi. We just got our Intex 12x30 metal frame pool. We started using HTH pool products. A friend suggested this site and I was wondering if I can switch to using the household products that you all suggest. What, if we are able to do so, would be the procedure. From what I read, I gather bleach (6%) takes the place of chlorinating granules, baking soda takes the place of TA increaser, and borax takes the place of ph plus. I am in need of a routine. I need to purchase the testing tubes. I this time I only have the 3 way strips. Any help would be greatly appreciated.
    Thanks so much.
    Default Re: Started to use HTH products for 12x30 metal frame pool Want to switch
    You would be doing yourself a favor to switch away from the hth products, in my opinion--these days they've added so much extra "mystery goop" to their products that it's really hard to tell what's actually going into your pool. You can absolutely switch to our methods, but there's really not a procedure--we're using essentially the same thing you are, just in cheaper and more pure forms Bleach does replace granules (but there are times when granules have their place), baking soda is exactly the same thing as TA increaser, and Borax is the same as pH plus.
    You do need to get your own test kit and not rely on strips--they are simply not accurate enough to run a pool with. We very highly recommend the K-2006 test kit linked in my sig--it seems a little pricey, but it will literally save you hundreds of dollars (not to mention headaches and swim time because your pool is pretty and clear) over even the first season.
    If you would take a few seconds and fill out this chart with your pool's info, so we don't waste a lot of time and posts going back and forth to get basic information, and get your test kit and post a set of numbers, we'll be glad to get you into a routine that will work for you
    Pool Chart Entry Form
    Pool Chart Results
    Jun 2012
    I filled out the Pool Chart Entry Form. I was unsure of this Thread Number. I hope that I provided all the information you need.
    cgm -- I couldn't find your username in the list. Check the Pool Chart results and tell me what line your info is listed on, please.
    Jun 2012
    #169 I put in the wrong PF User ID. Sorry this is getting to you so late. Can I edit the information?
    Ok. I thought that line might be you. You can't edit it, unfortunately. We have to do it, but it isn't something we are going to get to for awhile because we are so swamped answering posts right now. This is our super busy time up until the fourth of July and then things calm down a bit.
    When we are working to help somebody, we scroll through those results looking for a member's username and find their info. It will be quite confusing to anyone who is trying to help you when they can't find your name in the list so why don't you go ahead and just make a new entry with your correct username. That will make it easier for you to get help.
    Let me know when you have done so and I'll make a note to delete the other one.
    Jun 2012
    I created a new entry on the Pool Chart. Sorry about that.
    Ok. I'll make a note that the other one needs to be deleted.
    Order the Taylor K-2006 kit from my signature below and since it is only available online, get a kit to use in the meantime. Get a cheap OTO (yellow drops) / phenol test kit, or if available at YOUR Walmart (check availability), get the HTH 6-way DROPS test kit, which is compatible with the Taylor K2006. Test the pool as soon and you can, and post the results. If you get the 6-way kit, ALSO test the water you FILL the pool with, especially if it's a well, and post THOSE results as well. (The HTH is the best available kit you're likely to find locally, but it's not the K-2006. It can only provide rough measurements chlorine levels above 5 ppm, and it measures "TOTAL" hardness, rather than "CALCIUM" hardness, which is not ideal.)
    I would also suggest that you read a thread in the "Pool Chemistry for Intex-Type Pools." The thread I want you to read is the second stickied thread at the top of that forum.
    Come back with further questions and we'll go from there. Hope this helps.
Closed Thread
  1. Drain12 ft. Metal Frame Pool
    By TheKs in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-20-2012, 07:57 AM
  2. Need help with metal remover products
    By tina411 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-05-2012, 12:17 AM
  3. Timer for Intex metal frame pool?
    By drako4 in forum Pool Equipment & Operations
    Last Post: 07-13-2011, 07:12 PM
  4. Just a thought on metal out products
    By smallpooldad in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-27-2006, 12:29 AM
  5. Intex Metal Frame Pool
    By SBaker in forum Above-Ground Pool Construction & Repair
    Last Post: 06-01-2006, 11:48 AM
