Hi,
I setup my Intek 15' x 48" pool on Tuesday (4 days ago). I followed the great advice in this forum and appear to have my pool in good shape (chemical levels provided below), but the pool water has gone from crystal clear and very "blue" to having a slight greenish tint (still very clear). By greenish tint, I mean when you look through the water to the other side of the pool, the liner looks greenish instead of blue (as it did a few days ago). Why the change? Do I need to add some shock or something else? I look forward to any suggestions.
Measurements taken this evening using hth 6-way test kit:
Cl ~ 5
pH ~ 7.5
Alkalinity ~ 80ppm
CYA ~ 50ppm
Hardness Test --> after adding 5 drops of indicator, water did not turn red, turned very light pink. After 2 drops of titrant, water turned very light green (not blue as test describes). Pool water came from town water supply, not a well.
I ordered the Taylor test kit that is recommended, but still waiting for it to arrive. Are there any other measurements I need to provide? I look forward to your advice. Not sure if I have a problem or not, maybe everything is still good, just wanted to make sure and be proactive instead of getting into trouble with my pool water. FYI - the light greenish look to the liner is not algae, it is just how it appears when looking through the clear water.
Thanks!
Kevin
