Results 1 to 8 of 8
Thread: cloudy water
    Mar 2012
    Ohio
    Question cloudy water
    we had a stabilizer issue a few days ago, we have corrected it... but now we have cloudy water... How do I get rid of the cloudy water?
    my readings:
    hardness: 1000ppm
    total chlorine: 3ppm
    pH: 7.2ppm
    alkalinity: 120ppm
    stabilizer: 50ppm
    the only things added were stabilizer & shock over 24 hrs ago
    Quest (AGP)
    "24' round 14K gal AG vinyl pool; Sani-King Perform-Max 940; Hayward 110 SwimPro Element filter; Hayward 2.0 HP PowerPro pump; 24 hrshrs; hth 3-way test kit (drops)
    AquaChem 6 way test (strips); utility water; summer: solar; winter: vinyl / water bags; ; PF:8.6"
    Default Re: cloudy water
    What is the ingredient of the shock? What do you mean by a stabilizer issue? I think your cloudy water is a result of that high calcium hardness reading. What kind of filter do you have?
    Mar 2012
    Ohio
    when I checked the levels yesterday my stabilizer was low... We fixed that issue. We just got back from the pool store, we took in a water sampler... It was the hardness of the water... They gave us a 5 in 1 clarifier, & said that should solve the problem. He also told us we were over cleaning our filter, which is allowing small particles to pass through.
    We have a (cartridge filter) hayward swimpro voyager
    Quest (AGP)
    What is the ingredient of your shock that you used? What did you use to increase the CYA level? Don't add any more clarifier or anything else from the pool store at this time.
    Mar 2012
    Ohio
    We haven't add any shock since yesterday, it was a low chlorine shock & swim... (it was hth shock & swim (blue label)) The only thing added today was the 5 in 1, we only added 3oz.
    Quest (AGP)
    What Watermom was asking, was what the ingredient in the shock was..not the product name. Hth shock and swim is calcium hypochlorite. When you add a calcium-based product to a pool that already has sky-high calcium, you get milky/cloudy water, regardless of how often you're cleaning the filter--and it's not something that a clarifier is going to help with. You need to lower the calcium level in your water, and stop using cal-hypo for chlorination, otherwise this is going to happen every time you chlorinate the pool. What is the calcium level of your fill water? Also--what did you do to "fix the issue" of low stabilizer?
    Mar 2012
    Ohio
    That's what the guy at the pool store told us... He also said the shock we used (prior) was high in calcium. He gave us a different type of shock.
    & yesterday we added a stabilizer & conditioner....
    Quest (AGP)
    What was the ingredient in the "different type of shock?"
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 08:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
