Thread: Green Again
    May 2012
    Michigan
    Default Green Again
    The kids have been swimming A LOT in this HOT weather. The water level was down about 4-5 inches. Yesterday evening I checked the FC - 3.6. I added bleach and added treated well water from inside house (carbon filter, iron filter, de-ionizing water softener). I checked the FC last night after I raised the water level back up and the FC was 6.4. I woke up this morning and the water was green. Not bright green, but definitely green.
    I checked the CC and it was nonexistent. So:
    - What causes water to be green? Is it Algae only or are there other causes?
    - How often do you have to add water to your pool? I just added water last month and it turned green then too. But I let the FC get down to almost 0. This time there was definitely enough FC in the pool at all times.
    - Should I bring the FC up to 15 to get rid of the green?
    In hindsight I probably should have ran the filter all night.
    22,000 gallon gunite, Pentair Tagelus TA-1000 sand filter, Sta-Rite 1.5 HP pump, Intellichlor IC-40 SWCG, Pentair MasterTemp 250, K-2005 & K-1515 Test Kits
  1. Replies: 8
    Last Post: 08-04-2012, 10:43 PM
  2. Green, green, green and running out of patience.
    By marciastz in forum Dealing with Algae & Slime
    Last Post: 06-12-2012, 11:51 AM
  3. green water or green liner?
    By denanbob in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 11:16 AM
  4. green pool: like black/green pool
    By bazman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2010, 10:25 AM
  5. green green pool
    By mr greenpool in forum Dealing with Algae & Slime
    Last Post: 07-09-2006, 01:04 PM
