Results 1 to 10 of 14
Thread: Pool green 15,000 gallons
    Default Re: Pool green 15,000 gallons
    Membership upgraded. -ben
    (there are some stickies in the "Metals" section of the forum -- where I'm moving your thread -- that may help.)
    Another one. Darn. Now your thread is moved where it should be, so you can post again!
    Jun 2012
    SE Texas
    Cool Re: Pool green 15,000 gallons
    Woohoo I can post.
    OK I got a pool sample today.I will be using the pool store until I can get a kit.
    free chlorine =0ppm
    total chlorine=.3ppm
    combined chlorine =.3
    ph = 7.4
    hardness=290 ppm
    alkalinity w stabilizer correction=129ppm
    cyanuric acid=5ppm
    copper=0
    iron=0
    total diss solids=1500ppm
    They recommend adding 1/2 gal acid, 2lbs stabilizer and 5 lbs shock. I have been using super zappit but recently switched to clorox but I dont know how much to add.Any help appreciated. thanks in advance.
    Jun 2012
    SE Texas
    Man in my picture it looks good lol. It iwas just cloudy I hate to add stabilizer while it keeps eating chlorine. I need help lol.
    Ontario.
    Is the pool still green now? As you kill off the algae, it will go from green to clearer but cloudy and bluish until clearing up afterwards.
    Good read here.
    http://www.poolforum.com/pf2/showthr...You-have-ALGAE!!!
    To compute the amount of bleach/liquid chlorine this calculator is excellent.
    http://www.poolforum.com/pf2/showthr...18-bleach-calc
    Your ph at 7.4 is good, so I don't see why they want you to add 1/2 gallon of acid as that will reduce the ph, and makes no sense. Stabilizer can come after you get the water cleared up.
    The experts will way in, but for now, if the pool is not clear, you need to get the chlorine level way up above 10 ppm and keep it there until the water is clear. Chlorine is used up as algae is killed, so you need to check the chlorine level a couple of times a day and add bleach as needed to keep the level up.
    When you shock and the free chlorine goes to zero, it gives the algae a chance to bounce back and you lose ground.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    Jun 2012
    SE Texas
    Ok thanks. I will keep adding clorox daily till it clears.
    It doesn't have to be Clorox. Most of us use generic Walmart bleach.
    Ontario.
    Quote Originally Posted by biggun View Post
    Yup, it isn't elegant, basically keep hammering the algae with chlorine until it clears up :-)
    I opened very late this summer and my pool was dark green, couple types of water bugs, thriving ecoculture. I ran it up to and kept it at around 20 ppm and it was clear in 3 days. The only adjustment I made was to bring down my PH level as it was high. I balanced my water after the water was clear and chlorine levels down to normal levels.
    Also keep your pump and filter running 24/7, cleaning the cartridge as your pressure indicates. Many times, the cloudiness is due to dead algae that just needs to be filtered out.
    How's it looking now?
  1. BBB for small pool (6423 gallons)
    By sally1019 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-05-2011, 10:43 AM
  2. 8 gallons of bleach...still green!!!
    By Andersonian in forum Dealing with Algae & Slime
    Last Post: 07-03-2010, 12:01 PM
  3. How to determine how many gallons in pool?
    By cruzmisl in forum Above-Ground Pool Construction & Repair
    Last Post: 07-19-2006, 10:20 PM
  4. How many gallons is my pool?
    By shadowman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2006, 01:18 PM
  5. How to figure gallons in pool?
    By Poolidiot in forum Above-Ground Pool Construction & Repair
    Last Post: 05-16-2006, 07:21 PM
