Get a good kit--the K-2006, to begin with. Until it gets here, see if you can get your hands on the hth 6-way kit that some WalMarts sell, run a set of tests on your water, and post them back here. Keep the chlorine in the 3- 5 ppm range using bleach while you get a water analysis on your well water. You can go ahead and add a dose of Polyquat to help control algae, but you need to make sure it doesn't completely deplete your chlorine.
Is your water green and cloudy, or green and clear? To help us help you better, could you please take a few seconds and fill this short form out with info about your pool, so we don't waste a lot of time asking basic questions back and forth?
Pool Chart Entry Form
Pool Chart Results
