Thread: Pool open with winter cover on??
    psciotti Guest
    Default Pool open with winter cover on??
    I'm in Massachusetts and its still on the cool side (not to mention the buds still dropping from trees) to completly open the pool. Is it ok to run the pump (I cleaned it and put the bleach in this weekend) with the winter cover on for a few more weeks?
    I/G Vinyl 15K
    Thanks.
    Default Re: Pool open with winter cover on??
    No Problem with doing that. Is your cover solid or mesh?
    psciotti Guest
    It's mesh - I figured it would be ok but I wasn't sure if the high bleach content might somehow degrade the mesh cover.
    Thanks for the reply
    gregugadawg Guest
    would be a good idea to get it started, but don't add large amounts of chlorine until the cover is off as you will damage the cover if this was done repeatedly over time. chlorine is a gas and will affect the cover.
    poolbuoy is offline Registered+ Thread Analyst poolbuoy 0
    sturbridge,mass.
    I'm In Mass. I opened it on Monday and it's 73 already, With the solar collectors going today I hope to get 80 by tom. 90 and hot here tom. for memorial day! woo hoo!
    I would not shock until the cover was off either, I mainly just start clearing up the cloudy water using the filter and regular doses of chlorine so algea does not start growing.
  1. Live in Atlanta and want to keep pool open for winter...
    By georgiapoollover in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 10-09-2006, 02:32 PM
  2. When shocking, do I need to open pool cover?
    By trauh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-31-2006, 09:42 PM
  3. Winter Pool Cover
    By johnnyf0614 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-12-2006, 11:25 AM
  4. A Decent AG Winter Pool Cover
    By vinnygnj in forum Above-Ground Pool Construction & Repair
    Last Post: 03-25-2006, 10:18 PM
