Results 1 to 10 of 28
Thread: New Intex Easy Set 15' x 48" owner - first time pool guy
    BigDave's Avatar
    Default Re: New Intex Easy Set 15' x 48" owner - first time pool guy
    I'd seriously consider buying better cartridges for your new filter and setting up a cleaning regimin. See Ben's post #7 in this thread for detailed steps. If your new filter uses size B carts, you can find better quality carts here:
    Unicel C-5315 Replacement Filter Cartridge for 15 Square Foot Intex B Filter @ Amazon
    Jun 2012
    Long Island, NY
    No need for the cartridges any more, the sand filter is on the way
    BigDave's Avatar
    Ah, my bad, I didn't realize the 2650 was sand.
    Jun 2012
    Long Island, NY
    Hi All,
    Well setup went awesome... I had to move the pool from where I really wanted it because of a slight slope, oh well. The spot its in now is closer to the patio and on level ground, the setup and fill went perfect.
    First water test was done last night (Just TC) which was 13.5. This mornings test was TC: 13, PH: 7.2, TA: 20, CH:20. I added some borax to bring the PH up a little and will test later on today again.
    Pics:
    So, so far so good... I do have a question, what is that gray thing that came with the pool? Its shaped like a sail and made of PVC and vinyl?
    The ladder that came with this thing isnt the sturdiest... Any alternatives out there? I'd prefer to get something better.
    Maybe post a picture of the gray thing you are talking about so someone can help you identify it.
    The water looks inviting! You don't want the chlorine so high, however, with no CYA in there. also, you'll probably want to bump the alk up with some baking soda. It will help make your pH more stable. Aim for around 80-100.
    Jun 2012
    Long Island, NY
    Its high because of the initial shocking process I was taking. I'm going to work on the Alk tomorrow. Suggestions for amount of baking soda to bring it up to that 80 mark with the 3800 gal pool?
    I went in the pool today, little cold, but man it felt gooood.
    BigDave's Avatar
    Beautiful install; it looks like the picture on the Intex box!
    The gray plastic "sail" may be intended to be installed on the ladder inside the pool to prevent swimming under the ladder and getting stuck under water.
    How are you planning to add CYA?
  1. Intex Owner 15' x 48" overwhelmed
    By ATC_NH in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-13-2012, 04:49 PM
  2. New Intex 16' x 48" pool owner
    By losttree in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-14-2012, 10:50 PM
  3. looking for Help with intex ultra frame pool 12 x 36 (frist time pool owner)
    By jon56048 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-13-2012, 11:00 PM
  4. replacment ladder for 48" intex easy set abp
    By 4nick8er in forum Above-Ground Pool Construction & Repair
    Last Post: 06-01-2011, 09:23 AM
  5. Easy Set Intex Pool
    By Naunnie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2011, 05:04 PM
