Results 1 to 10 of 33
Thread: Chlorine block-need recommendations
    Default Re: Chlorine block-need recommendations
    If you want to get a handle on how severe the problem is, you may want to read this page on testing for chlorine demand.
    Jun 2012
    Maryland
    Ok will do this also. Still waiting on my test kit. Thank you!
    Jun 2012
    Maryland
    I did my test, need some guidance. Here are the results: ph-7.4; TA -170 ppm, CH- 3000(this seems wrong?); FC -.5 ppm and .5 ppm TC. We added 12 bags of shock and two gallons of liquid shock. Husband hasn't done the bucket test yet.
    Yeah, try that CH test again. Did you do the CYA test? What kind of shock --- ingredients, please. You are using the K-2006 kit, right?
    Jun 2012
    Maryland
    Ok this time I got CH of 260. CYA I can't get it to read because both times I tried the solution wouldn't cloud. Yes 2006 c test kit. Here's what we put in last night: 2 gallons liquid shock- (sodium hypochlorite 12.5%nand 12 bags (1 lb each) calcium hypochlorite 73%. Ugh so frustrating...I'm lost. Lol. Thanks for any help.
    May 2012
    Florida
    it can get frustrating but just do what the mods say and you will get your pool whipped into shape. with regarts to CYA, are you confident you are doing the test correctly? if so then it sounds like you have very little or no CYA at all, and you will need to get some in there if thats the case. im running high CYA ( around 110/120ppm ) and love it, but high CYA may not be the best bet for all. most folks will run around 50ppm CYA.
    18' round 7.5K gal AG vinyl pool; bleach; waterway cartridge filter; waterway pump; 12hrs; taylor k-2005 and taylor k-1515a; utility water ; summer: none; winter: none; ; PF:16
    Quote Originally Posted by Jess6521 View Post
    That just means you have ZERO stabilizer present. You might want to watch the videos, here: http://www.poolforum.com/pf2/showthread.php?17157
    Jun 2012
    Maryland
    We are conducting our bucket test currently on the third teaspoon of bleach added to the sample. Getting a 13 of FC and a zero on CC....
    I'm also realizing, as I read the bucket page again that this may not be for me. When we dosed with bleach we held chlorine overnight, but then lost it by noon. Sigh...what to do now.
  1. Chlorine Block?????
    By JoyceMarie in forum --cleanup--
    Last Post: 06-07-2013, 03:10 PM
  2. Concrete block method
    By tybeeware in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2006, 03:53 PM
  3. Chlorine Block?
    By sandysfreckles in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-05-2006, 10:57 PM
  4. Patio block question
    By NWMNMom in forum Above-Ground Pool Construction & Repair
    Last Post: 05-08-2006, 05:53 AM
