Hi I, like many others here I'm sure, am a brand new pool owner. I have an EasySet Intex pool that is 16 ft across and 42 inches deep. I am having a terrible time with Chlorine. I did do some research before putting things together but it didn't seem to help as I am as confused as when I started. I have both granules as well as the 1" tablets. Both are HTH brand. I put the tablets into a floating dispenser but learned quickly they didn't dissolve at all basically. So I moved on and bought the granules thinking if I got the level to the 1-3 ppm that it needed, that I could use the tablets after the fact to maintain that level. That has not appeared to be the case either. All other levels such as pH and the alkalinity seem to be fine. There is no algae in the pool and we did swim once and had no lasting effects as I was able to get the chlorine to the right level using the granules over the weekend. I now sit here both confused and frustrated over the whole situation. Everything I have read about the tablets says they are wonderful and the best method to use. But I am achieving nothing but headache from them as they simply won't dissolve. The same tablets have been in there for a week now.
Sorry for the longwindedness but I wanted to be sure I gave enough info to be able save my sanity as I am certain you will be able to get me up and running and keep me there. Thank you in advance for your help.
