Donovan,
A few threads for you to read (obviously the whole threads won't apply to your situation but you may get some helpful info from them):
http://www.poolforum.com/pf2/showthr...lorine-Allergy
http://www.poolforum.com/pf2/showthr...pm-bad-for-you
I also talked with Ben and he suggested that you try and isolate which specific ingredient might be causing the problems by using them one at a time in the bathtub. (It was mentioned in threads I referenced.)
To cut and paste what he told me this morning:
"There's a thread in China Shop abt chlorine allergy u can point him to. But he'll need to do single item testing in the tub with just legs. I'd go polyquat, bleach, borax, dichlor. Once he has enough chems to maintain a pool, he can drain & refill. Chlorine alone is not the problem, but chlorine is rarely alone -- so no telling what's actually in his pool!"
Do them in the order he suggest above starting with the Polyquat. If that product causes no sensitivity issues, then you can proceed to the next one. Always drain and rinse out the tub well before using the next item.
When you get to the point of testing the dichlor, please don't use the product you used before. Actually, we usually only recommend using dichlor purchased at Sam's (100% dichlor) or Amazon's Kem-Tek dichlor.
The Polyquat is 60% which is the only algaecide we recommend.
Let us know what you find out and then I'm sure Ben will be around to advise you further. Hope this helps.
