A few days ago, I noticed water running down my tank from under the Multi-Port. After removing the Multi-Port, I found a hairline crack in the tank. Not being able to purchase the exact 22 inch American Products Eclipse tank, and not wanting to alter my pipes, I started looking for a sealer that would seal the small crack. The problem was finding an epoxy that would stick. After trying 4 different ones, I stumbled upon a product called Flex-Set available from West Marine. I figured this would be my last attempt before biting the bullet and buying a replacement tank. I sanded across the crack and used a PVC pipe cleaner to remove any residue, applied the product per instructions and it worked. Takes 24 hours to set. This is the best $24.99 I have spent in a long time.........
