Results 11 to 19 of 19
Thread: Cloudy water after filter change
    Jun 2012
    Default Re: Cloudy water after filter change
    Yeah, ammonia demand sounds right. I don't know what my CYA was last year, but all we have used the last two years is dichlor shock once a week and trichlor mini-tabs all season. We moved in two years ago and I have been relying on the pool store for everything. No more!!!
    Glad I found this site. I would have been further in the pool store web of chemicals. Thank you so much!!
    Jun 2012
    Okay, I just wanted to give you an update.
    So far I have put in 15 bottles (1.42G) of 6% household bleach and 5 carboys (5G each) of 12.5% liquid chlorine. That's 21.32G of 6% and 25G of 12.5%. By my calculations that is (21.32*.06)+(25*.125) = 4.4G of pure chlorine. Or (4.4G/27,000G)*1,000,000 = 162.96ppm for my pool.
    Here are my readings as of 5:45 this morning:
    FC: 3
    CC: 1
    pH: 7.0
    Alk: 75 (test turned dark red at 7, pink at 8)
    I have put 5 boxes (76oz each) of borax and it has stayed above 7.0 for most of the time. But something in the shocking process is bringing down my pH.
    For the first time in 2 weeks I can see the deep end!!!
    My FC levels obviously didn't hold overnight, but its the first morning test I have had where FC is over 2 and CC is less than FC. Most of my morning tests have been around FC 3 and CC 5. I have to work today, so my plan is to put another box of borax in to try to bring the pH up during the day and start shocking again in the evening (around 6-6:30). Then I will test every hour and bring FC level back up to 12-15ppm until bedtime (11:00) and test again in the morning. I will keep repeating this process throughout the week until I can hold my FC level overnight.
    Thanks again for you help and support!!
    You are welcome. Keep us posted how it is going.
    Hang in there--it'll work, just don't give up
    Jun 2012
    UPDATE:
    Water looks amazing...crystal clear!! I am still losing FC overnight, but all of my readings for CC have been at or below 1. My last test at 10:30 last night showed FC 10.5 and CC at 1. Here are my results from 5:45 this morning.
    FC: 3
    CC: 0.5
    pH: 7.6
    Alk: 85
    I do have one question. I am going to continue to shock until I can hold FC overnight, but should I start using Dichlor to raise my CYA levels?? They are at zero and I am concerned about have NO chlorine in the pool during the day. Using the Pool Calculator, I could use 5lbs of Dichlor and bring my FC into my 12-15ppm range while also introducing 11ppm of CYA. Obviously, I would watch these levels with a target of about 30ppm(??). Once I hit those levels, I could switch back to liquid chlorine if necessary. Anything wrong with this strategy??
    Thanks,
    Jim
  6. #16
    You can use dichlor but just be aware that as the CYA level comes up, so does the needed shock level to kill whatever is in your pool. If you haven't already done so, please read the Best Guess Chlorine Chart in my signature. I would also suggest a CYA level of around 50 as opposed to 30. (Actually, maybe aim for 40-45ppm and that way if you overshoot a little, you'll still be ok.)
  7. #17
    Jun 2012
    Great. Thx!
  8. #18
    Also, forgot to add that you'll also need to watch your pH as well. Dichlor (and trichlor for that matter) are both acidic and will drive the pH down.
  9. #19
    Hi Jim;
    Here are some things that may help:
    1. Link to the chlorine demand bucket test -- it will allow you to estimate how much further you have to go.
    2. Links to our online pool history chart -- if you add the data, I'll turn on the graphing:
    Pool History Chart
    Pool History Results
    3. Links to the online pool chart, allowing us quick access to your physical pool info:
    Pool Chart Entry Form
  1. Clogged filter, cloudy water.
    By timo14 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-21-2013, 12:41 AM
  2. cloudy water with a new sand filter
    By franky2011 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-02-2011, 03:57 PM
  3. DE filter/cloudy water
    By dsimpson in forum Pool Equipment & Operations
    Last Post: 05-17-2011, 08:56 PM
  4. Cloudy water- Cartridge Filter
    By johnnyf0614 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-11-2009, 10:47 PM
  5. Change from sand to Zeolite, water now cloudy
    Last Post: 05-29-2007, 05:24 PM
