Thread: Hayward Super Pump question
    Jun 2012
    PA
    Default Hayward Super Pump question
    Hi,
    Seeing a thread about one of these pumps brought to mind an issue I'm having with mine. When it shuts off, occasionally it makes a noise like it is still running - kind of a 'whirring' sound of descending pitch until it finally stops. I've never had a pump do this before. It is only 3 years old and has always worked fine. Pressure, etc. is good, but it's just weird that it makes that noise - almost like the water pressure is forcing it to spin the other direction as soon as the filter shuts off (?) Any ideas? It also sounds just a bit louder when running then it did before.
    Thanks,
    Keith
    Honesdale PA
    Default Re: Hayward Super Pump question
    If you have a lot of trapped air under pressure in the filter, that can sometimes cause a backflow after the pump stops and the air bubble expands....unlikely but possible. Question....do you see any water coming back out the skimmer when you kill the pump? If you're getting a reverse water flow you should see it there.
    Edit: Not sure but I don't think running water through a centrifugal pump backwards will spin the impeller.
  1. Hayward super pump 3/4 ?s
    By Messina1974 in forum Pool Equipment & Operations
    Last Post: 06-27-2013, 10:34 AM
  2. Hayward Super Pump is Super Noisy
    By moneypitpool in forum In-Ground Pool Construction and Repair
    Last Post: 07-25-2011, 10:16 AM
  3. Hayward Super Pump - Super Hot and Shutting Off
    By CapitalBoo in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 09:32 AM
  4. Hayward Super II pump question
    By thefunkie1 in forum Pool Equipment & Operations
    Last Post: 10-02-2010, 08:35 PM
  5. Hayward Super pump question
    By Deuce2 in forum Pool Equipment & Operations
    Last Post: 07-19-2007, 11:09 PM
