Results 1 to 10 of 14
Thread: Pump Doesn't Pump....Just Hums
    skantner is offline ** No working email address ** skantner 0
    Default Re: Pump Doesn't Pump....Just Hums (maybe it doesn't know the words:)
    You saved me! I just went out to the pool and got my pump started by following this mostly verbatim...right down to the wrench size. I had to move some electrical components out of the way to get the wrench in. I did manage to avoid getting shocked by the capacitor, though now it is time to shock the pool...
    Thanks a million!
    //Scott
    Quote Originally Posted by waste
    Null and wolly, welcome both! to the forum!!
    Hard, kill the power to the pump, open the back of the motor (using a small 'regular' screwdriver or a 1/4" nut driver to unscrew the two securing bolts - if the problem is what I think, you'll have to use the 'flat'(regular) screwdriver to pry the cover off, and possibly a hammer to get it off) (the bolts won't come out of the cover, so don't waste your time trying to get them all the way out, but be sure that they aren't still 'threaded in') Using a 7/16 open end wrench try to 'lock on' to the back end of the shaft (it's dead center of the pump, has 2 flat sides hidden behind a white plastic ~triangle that has 2 copper strips ending in white plastic rings forming another triangle) Odds are you won't be able to get the 7/16 wrench on it (there's only 1 clear path to get the wrench in there and the shaft usually isn't positioned to accept it ;( ) - watch out for the capacitor (the black tube that's about the size of a 'D' cell battery, if you touch it's posts, you'll get shocked). However, if you can lock on the shaft, work the wrench up and down a few times, if it moves for you put everything back together and fire up the pump, should work. Be sure to look for water dripping out of the bottom of the pump if you get it going, if you see some look at the next paragraph.
    Cool Re: Pump Doesn't Pump....Just Hums
    Scott, welcome to the forum!! glad ! to have helped.
    For both you and Nullqwerty (Null, do you use the Dovorac {sp?} keyboard?), I reiterate to check the bottom of the motor for drips, when the shaft seizes up, the shaft seal assembly usually goes too. Just trying to save y'all some lost water and more headaches. - Waste
    I found this forum today as I *sigh* seem to be having the same problem here in Chardon, OH. Although when I reached in with my 7/16 and turned it back and forth (was able to do so - without getting shocked it didn't seem to make a difference. Here are details: pump certainly seems to be running ok (starts up ok) but I have low flow. I am going directly to waste (bypassing the filter). I replaced all suction side pipes and it is air tight. In fact, when I turn off pump, I hear a swoosh of water that kicks back into the basket from the pump. When I open the basket lid the presuure relieves. So it seems like I have plenty of pressure but the water doesn't want to move for some reason (well, a little bit of water is moving but not much)...the pressure gauge isn't moving - just site at 5psi. I reached in and checked impeller which moves fine and doesn't appear to be clogged. It looks like I might have to tear the pump apart? Any other ideas on what's happening? Thanks very much for any insight.
    Broken Arrow OK
    I just went through a slightly similar problem with the low flow/no pressure problem. My housing was cracked on the pump basket and sucking in air. I wasn't able to see the water squirt out when shutting down due to the low pressure. Also the crack was at the very bottom.
    RICK, welcome to the forum!!, you may have a clogged impeller or as Imnharris points out, a cracked pump housing. (there are a couple of other things, but they are much rarer). Check the lid of the housing for air bubbles - if you have air it will mean 1 thing, if not another.
    Mayhaps this should be moved so as not to take over the origional post - Waste
    thanks a ton. i did post a new topic (baffled-low flow) and I remain baffled...how can I check for a cracked housing?
  1. Recommendations For Replacement Pump Or Pump Motor (1.5" Piping, High Head)
    By ChuckDavis in forum Pool Equipment & Operations
    Last Post: 05-25-2013, 04:56 PM
  2. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 08:37 PM
  3. Whisperflow Hums won't Start
    By craigrpeters in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-04-2010, 11:33 PM
  4. pump hums
    By poolhelp101 in forum Pool Equipment & Operations
    Last Post: 06-04-2008, 04:16 PM
  5. Pump just hums, won't turn over at start up
    By dbursch in forum Pool Equipment & Operations
    Last Post: 04-21-2008, 08:44 PM
