Thread: Pump noise after seal change
    Jun 2012
    Pennsylvania
    Default Pump noise after seal change
    I just changed the seal in a Hayward 1 hp pump and now the pump I running a little noisy. No leaks and pressure is fine. Any ideas out there as to what may cause this before I tear it apart?
    Default Re: Pump noise after seal change
    Welcome to The Forum!
    My first thought is that the impeller might not be fully tight. The other thing that jumps to mind is that a pebble, or something, might have gotten into the housing when you did the change out.
    Jun 2012
    Pennsylvania
    Quote Originally Posted by waste View Post
    I checked out the pebble situation in the housing and found a lot of DE(I was putting DE in when all this was happening) I cleaned all up and tried again to find the noise still there. Now I'm beginning to think DE has gotten into a motor bearing. Is it worth replacing a motor bearing or will the DE eventually go away?
    Ed
  1. To seal or not to seal: marble coping and deck
    By famousdavis in forum In-Ground Pool Construction and Repair
    Last Post: 07-26-2011, 02:43 PM
  2. pump noise
    By aubratgyrl in forum Pool Equipment & Operations
    Last Post: 05-06-2009, 08:53 PM
  3. Pump noise
    By Phillbo in forum Pool Equipment & Operations
    Last Post: 10-13-2006, 07:18 PM
  4. Booster pump (PB4) seal leak
    By vgg659 in forum Pool Equipment & Operations
    Last Post: 09-03-2006, 09:21 AM
  5. Pump seal for Hayward super pump?
    By goosegunner in forum Pool Equipment & Operations
    Last Post: 05-22-2006, 01:34 AM
