Closed Thread
Thread: bad spot in shallow end
    Kentucky
    Default Re: bad spot in shallow end
    I would certianly have your contractor come 'look' at it. If it's actually on the bottom - there's not much that can be done other than draining the pool, and pulling the liner back to repair the hole.
    I have a few of these on my Vinyl IG where the slope into the deep end meets the hopper wall. They are soft - but not totally hollow. The builder stated that they could fix them (draining more than 1/2 my water, and the _possiblity_ that I would have problems getting the liner to go back in 'just right').
    He said however that it most likely wouldn't cause any problem unless it got larger.
    That said - i live in a fairly wet area, and it's likely that just a small area on that particluar spot has sunk in due to water behind the wall (high water table). If you live in an especially wet area this could also be the case - but since the pool is brand new - I would be concerned.
    My main concern would be a pinhole in the liner that could be leaking water at that spot, causing the sink hole.
    Good luck.
    Dec 2005
    Denham Springs, Louisiana, USA.
    Thank you for your help. I have a call into my pool builder
Closed Thread
  1. how to reattach vinyl liner in spot where it's slipped out of the "channel"
    By tenax in forum In-Ground Pool Construction and Repair
    Last Post: 08-06-2011, 06:44 PM
  2. Growing black spot on bottom of gunite pool
    By love2float in forum In-Ground Pool Construction and Repair
    Last Post: 05-15-2011, 04:42 PM
  3. External Pool Spot Lights - High Voltage or Low Voltage?
    By CJDahl in forum In-Ground Pool Construction and Repair
    Last Post: 01-16-2007, 10:31 PM
  4. Do I have to level to the lowest spot within pool area?
    By robin640 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-27-2006, 08:41 PM
  5. Too Shallow!!
    By HAYMAN in forum In-Ground Pool Construction and Repair
    Last Post: 04-26-2006, 01:53 PM
