Results 11 to 13 of 13
Thread: SWCG shows low flow all the time.
    Default Re: SWCG shows low flow all the time.
    Quote Originally Posted by Rosie700 View Post
    How much should I add?? Thanks for your help!
    A 'guess-timated' cup. Add, allow the pump to circulate for 1 -2 hours, retest.
    Jun 2012
    Wisconsin
    Thanks, I have gotten the CL and PH a lot better now. any other suggestions for me??? PS Thanks soooooooo very much for your help.
    Date Chlorine PH Alkalinity hardness cyanuric acid
    6/9/2012 0 7.8 300 400 water stayed clear add shock
    6/10/2012 0.5 7.8 330 400 NA Added 9oz of CYA after reading add shock
    6/11/2012 3 7.5 300 370 less then 30 Added 9oz of CYA after reading
    6/12/2012 3 7.5 280 390 35 12 hours boost over night before readings
    6/12/2012 1 7.5 NA NA NA 2 hours after adding 12.0 oz of liquid Muriatic acid
    6/13/2012 1 7.2 270 350 NA next moring after adding 18.4 total oz of MA
    6/13/2012 5 7.2 NA NA NA reading 1 hours after added 8oz of shock
    May 2012
    Oklahoma
    I initially had the same problem with my SWCG system from Intex too. Even covered and skimming all the grass, tree junk or whatever before I do cover it for the night, I find that as soon I do uncover the pool say a day or two later, I generally have enough crud in the return cover to take it off and clean it. With your small pump, this will be the most critical factor for you. Great job of figuring that out!!
    Get that Taylor 2006C......it will afford you exacting test results so you can dial that pool in exactly where you want it.
    Bob E.
    Intex 10' x 30" metal frame pool, Intex 2500 gph filter/pump, Intex Saltwater generator, SwimMax 11KW heater, 2 x Small Game Solar Domes.
  1. DE filter causing flow problem for SWCG & auto prime on pump
    By PJM361 in forum Pool Equipment & Operations
    Last Post: 07-15-2013, 06:31 PM
  2. How long before the brown shows up?
    By Bosch232 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-14-2013, 11:18 PM
  3. Best time to run pump / SWCG?
    By Phillbo in forum Pool Equipment & Operations
    Last Post: 07-03-2007, 09:16 PM
  4. Design flow rate vs maximum flow rate...
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 07:50 AM
