You are very welcome!![]()
one more question...clorine is now holding. but after swimming today, the pools deep end seems a little foggy. i can see the bottom and all, just doesnt seem perfectly clear. this happened yesterday too after swimming but i did need to add bleach last night and i did add 1 1/2 gallons. the pool looked great today before swimming. my numbers tonight are:
cya 30
FC-5
CC--it just very slightly changed after the drops, but did not turn completely at all
PH-7.6
TA-110
pool temperature is 82, i do have a heater.
let me know what you think is going on to make this happen after swimming and what i should do, if anything. Thank YOU!!
Last edited by poolhelp101; 06-16-2012 at 11:07 PM. Reason: make the post a little clearier
Sometimes mine does that after the kids have been swimming if there's any dust/dirt/pollen/sand in the bottom of the pool. It gets stirred up during the swim sessions. Some of it will get caught by the filter, most of it just settles back down into the seams of my liner overnight while the pool is off. If that's the case in your pool, let it settle overnight, then vac it out. If it doesn't bother you, just accept it as fact and don't worry about itIf it looks at all greenish, or if you lose any chlorine at night (test at night and again in the morning before sun is on the pool), then just shock it one more time and it should finish clearing it up.
